maybe this will help.
thank you Google
Answer:
CRD files are Misc Files primarily associated with Windows Cardfile.
CRD files are also associated with ColdRED Script File, Guitar Chord File, Spanish Whiz Card Game Sound File (GB Blanchard) and FileViewPro.
Additional types of files may also be using the CRD file extension. If you are aware of any other file formats using the CRD file extension, please contact us so that we can update our information accordingly.
How To Open Your CRD File:
The fastest and easiest way to open your CRD file is to double-click it. This allows the intelligence of Windows to decide the correct software application to open your CRD file.
In the case that your CRD file doesn't open, it is highly likely that you do not have the correct software application installed on your PC to view or edit CRD file extensions.
If your PC opens the CRD file, but it's the wrong application, you'll need to change your Windows registry file association settings. In other words, Windows is associating CRD file extensions with the wrong software program.
We highly recommend scanning your Windows registry for invalid file associations and other related registry issues.
