- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Dear friends,
I have been working on a road project abut I am down with a problem that I tried to solve for these two days but could not find an answer yet.
I designed a road of 8200 m and the road alignment has nearly 30 curves. Road width is 10 m (composed of two lanes with 3.75m lane width and 1.25 m shoulder width.) WB20 type vehicle will move on this road hence I need to apply widening for curves. I use offset alignment command to create target offsets. This is how I define alignment offsets.
Then I create an assembly with "Lane Outside Super With Widening" because corridor width will increase at curves. Hence, I set targets for the assembly while creating the corridor.
However, as a result, after the corridor is created, lane sides do not match the target lines as below. What is the problem with the mpodelling?
