Civil 3D Forum
Corridor Transition In Offset Subassembly
3 REPLIES 3
nkiakas
168 Views, 3 Replies
Good afternoon
I tried to apply corridor transition (new version tool) on a subassembly of an offset assembly and the command is not applicable or not working.
Did anyone try it before?
Thank you
Labels (1)
3 REPLIES 3
SoaresASBCAD
in reply to: nkiakas
nkiakas
in reply to: SoaresASBCAD
Hi, @SoaresASBCAD thanks for the response.
I watched the video, it's nice and clear but he did not try it on a subassembly attached with offset assembly.
During the command of subassembly selection, C3D is not responding to the selection of subassembly attached with offset assembly.
I will try it again and come back. Maybe I missed something.
mpryor433
I'm having the same trouble. Very frustrating. To put it another way, we can't edit an assembly that has an offset, or rather we can edit the subassembly attached to the main assembly but not the subassembly that's attached to the assembly offset. When prompted to select a subassembly it does not highlight the offset assembly so that you can pick it. For the baseline, I've tried it with the parent alignment as well as the offset alignment with no difference.
Rail Community
