Corridor transition between assemblies: daylight basin
Hi everyone. I'm trying to model an embankment, created as a corridor (editing the geometry through allignment and profile). I need the wall to have different heights on different portions with specific slopes: I made different assemblies for each case, with the same target (existing ground surface). Let's take the assemblies A and B as examples: they're created with the same daylight subassembly tool, chosen from the default given tools. They just have different heights and lenghts.
I would like to obtain a smooth transition between the 2 sections (connecting A1-B1, A2-B2, A3-B3, A4-B4).
I think I need to create another region in between, where the transition will take place, with an additional assembly.
I can't find the way to do it.
(If I leave an empty gap between the 2 regions, the corridor will have a missing portion).
Help please!
Wojtek_Garczewski
Hi @Anonymous
Thank you for posting.
Have you tried to create an additional region between A and B, that will follow some horizontal and vertical targets (i.e. featureline) to create a smooth transition between regions?
 Looking forward to hearing from you.
Wojtek
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Wojtek G.
Product Owner for Civil 3D
Civil Engineering Solutions
Thank you for the fast reply. I tried to manually draw feature lines (with 'creating feature line') that connected the A1-B1... etc. vertices (you can see one green line in my previous image that survived from a previous attempt). In the end I couldn't set them as horizontal-vertical targets because I don't know where to give this kind of instructions. Would you mind giving me some more detailed advices about your method? (I'd like to know, for example: do I need to set these targets in the corridor properties or in the assembly/subassembly given to the new region? Indeed do I need to crate a new assembly for the new region?). Thank you so much.
Wojtek_Garczewski
Hi @Anonymous
It's hard to predict, as I don't know exactly what type of subassemblies you used.
Basically, we set up targets in the Corridor Properties upon Parameters Tab.
Please see:
Civil 3D Select Corridor Targets
However, not all of the subassemblies allow for horizontal/vertical targeting.
The best way is to create a new assembly that contains subassemblies that can be targeted, and use it in a new "transition" region.
Please see some helpful links:
About Corridor Targets
To Specify Corridor Targets
Civil 3D 2010: Corridor Targets - VIDEO
Wojtek
Wojtek G.
@Wojtek_Garczewski thank you, it's clearer now! I succeeded in making my transition region, with three feature lines (check out the image), used as targets by my three subassemblies (LinkWidthAndSlope). It worked great, that's a pity that the feature lines do not adapt when I modify my corridor, and the transition region will need to be fixed manually by snapping the feature lines again to the edges of the contiguous regions. I just wish you could deny that!
