Civil 3D Forum
Corridor Target Issue
3 REPLIES 3
451 Views, 3 Replies
I am trying to grade a simple cul-de-sac and intersection using the Corridor and Intersection tools. Everything looks pretty good however there is a bit of an issue with the way the corridor is targeting the finished grade profile through the cul-de-sac (see the attached image). It seems it is trying to target the alignment further back then areas adjacent to the cul-de-sac alignment that was created.
I have attached the DWG file as well.
Appreciate the assistance.
Labels (1)
3 REPLIES 3
Udo_Huebner
@Anonymous
I can reproduce this issue as well. I think this is not the expected behavior and should be reported to the Support Team. However i figured out a workaround to avoid this behavior.  Split the Region into two regions and the corridor object displays as expected.Workaround for corridor cul-de-sacWorkaround for corridor cul-de-sac
P.S: The Screenshot was made with the German Language version of Civil 3D.
Gruß Udo Hübner (CAD-Huebner)
in reply to: Udo_Huebner
Thank you for your response and the solution worked great.
Much appreciated!
We've had to split regions to solve this issue when a horizontal target ends within a region. Its as if the corridor is still looking for the target behind it.
Splitting the region is the current solution.
Rail Community
