Corridor Surface irregularities & Quantity Takeoff
bforr
Advisor Advisor
bforr
C3D 2021
Have a corridor that I created a surface on for Quantity Takeoff.  Attached are images of QTO hatching of sections and corridor surface build.
The QTO hatching is different in the sections.  Some hatching completely cover the corridor, some miss a lower quadrant (so to speak), and some miss two lower quadrants.  See images.  Notice these are 100' apart.  Would like the hatching to completely cover the corridor section.
It must be the way I built the corridor surface.
ecfernandez
Hi @bforr, use overhang correction by bottom links, and your datum surface will be constructed properly. Also, consider adding a boundary to that surface to avoid triangulation outside the limits of your corridor.
Best regards!
Camilo Fernández
P.Eng | Transportation
LinkedIn
bforr
Thank you for your direction.  Easy fix it was.  I have created them in previous versions and had read some of the help yesterday and watch a video on constructing surfaces before I posted, saw some mention of overhang corrections but didn't discover what that was.  Should have.
ecfernandez
Glad to know you solved your problem. Happy to help. Best regards! 🙂
Camilo Fernández
LinkedIn
