Corridor Surface datum link is not forming properly
alialp97
alialp97
I want to create datum surface to calculate cut and fill material but datum link does not follow assembly bottom and it does not intersect with the existing surface.
Project file and section view screen shot are attached.
Thanks in advance.
RobertoJJoaquin
@alialp97 Your problem is that at some points in your corridor the links are overlapping. I am sending you images of the error and highlighting what is happening.
1. Problem with the overlapping of corridor links. This can be solved with the option to see image A.
2. Problem with the alignment radius. This can be solved by modifying the type of curve.
3. Problem with the absence of a curve. This can be solved by creating a curve in this PI.
Check the attachment and tell me if it is what you were looking for, I have added a radius of 8 meters and I have given the other a better tangent connection, tangent.
Regards
Leave a like! If you found this helpful.
If your query has been solved, mark it as a solution. This will help other people find it easily later.
¡Deja un like! Si te fue útil lo indicado.
Si tu Consulta ha sido solucionada, marca como solución' esto ayudara a otras personas a encontrarla fácilmente a Posterior.
alialp97
Thank you so much for your help. I saw my mistakes and It happened as I wanted.
Best regards
