Corridor Surface Boundary Eliminates Half the Surface
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am grading a culdesac, and I have a corridor with two baselines (one for the north and one for the south side of the culdesac) in one corridor. Both are set to daylight to the existing surface. When I create a corridor surface and use "corridor extents as outer boundary," it only creates the surface for half the corridor (one baseline). If I remove the boundary, it completes the surface but of course it has extra triangles outside the corridor. I know I can remove the boundary and delete triangles as a workaround, but I'm hoping there's a better solution. I found another post from someone with this problem several years ago, but no solution was found. Screenshots attached show my corridor selected, the surface with the boundary added, and the surface without the boundary added. Thanks for the help!
