Hey,
Im trying to extract corridor solids but I have alyways problems. When I try to export it as 3d sweep its almost okay, but cut and fill are invisible. If its as 3d sample, cut and fill on curves are straight like in tangent. Im trying to make solid, to can use it in Revit and then probably render. How can I make it to looks line as corridor? Thanks!
Hey,
Hi @apdim, As far as I know, Cut and Fill areas won't be exported as solids unless they are "Shapes." What you can export is the Cut or Fill Slopes, which are represented by the daylight line. If you need the cut and fill, you can attempt to resemble it by creating a custom subassembly in Subassembly Composer. Use SurfaceLink to drape the terrain. However, this is a challenging task!
Best regards!
Best regards!
They are already defined as shapes...
Hey everyone,
1. I managed to fix my main issues-one of the points was pointing at surfaceand it wasnt creating link. Now its fixing and its working correctly IN Civil. But now I hav4e another problem. When I create corridor solid-when there is transition between cut and fill-it breaks solid. Actually it connects all fill together, all cuts together ant etc. How can I avoid it? Im attaching dwg with solid. Thanks!
2. Also I still cant create good visualisation of the project. When Im trying to add hatch to links-its invisible. In corridor code set I have enabled everything, but I cant still see solid hatch to links. Is there way to hide everything under surface? Now it looks like that:
I want to be kind like that:
Hey everyone,
