Corridor section editor - huge display
jrogulski
jrogulski
My corridor section editor is showing everything that is in file. Display view is showing not only a corridor, but also text and polylines that are far away from this corridor. So, each time I open section editor, my left offset is -100,000, right 60,000. I can select those polylines and text and I'm pretty sure those are my problem. Going to next station, and any other station, offset is similar. How can I organize view of section editor to show corridor only?
Zoom to subassembly or offset/elevation are not working.
Elina.P
Autodesk Support
Autodesk Support
Hi @jrogulski!
When selecting the station by going into Corridor Editor, that station will be the one showing in the Section Editor ribbon.
Note: The command that controls this behaviour is ViewEditCorridorSection, found in the Settings tab under Corridor commands.
But also, remember to install all the latest updates and fixes for Civil 3D, as most of them contain minor issues from previous versions (it is like that for version 2021 with section view).
Hope this information helps you to resolve your issue!
Elina P.
Technical Support Specialist
Civil Engineering Solutions
