Corridor not following centre alignment help
wol000
wol000
Hi Folks,
New to civil 3d. I'm having an issue with my corridor not following my alignment and tieing into an joining road. There is an offset alignment line for the adjoining road, but no matter what I target I get a bump at the crown. The longsection looks fine and connected perfectly, any help would be greatly appreciated
Replies (8)
Can you share that C3D file ?
wol000
Hi Gurulal,
the file is to large to post, thanks for getting back to me. I've looked at it a bit more. The assembly is targeting the existing ground at a certain point along my alignment, If I add the crown and lane to my corridor surface, it fixes one side only, I can throw up a few pictures
Hi wol,
Did you try to match proposed profile elevation with adjoining road elevation, i think that's the problem.
wol000
Yeah, at that point on the long section were they cross the level is good. When I flip the model into iso view and I.d the point it’s 60mm higher in the corridor
If possible Please attach the file.
or send me here :- gurulalsingh80@gmail.com
JRitner
I typically run the corridor for the perpendicular road up to the curb returns and stop it. Then I create a separate curb return assembly and run it along the feature line or curb return alignment, as the case may be, targeting the CL & Offset alignments and profiles of the intersecting roads. See pics below...
Connected curb return alignmentsConnected curb return alignments
Bottom assembly is for returnsBottom assembly is for returns
Intersecting corridor definitionsIntersecting corridor definitions
Set alignments as width targetsSet alignments as width targets
Set FG Profiles as elevation targetsSet FG Profiles as elevation targets
Completed return corridorsCompleted return corridors
Finished IntersectionFinished Intersection
As long as you're vigilant about naming all your alignments, profiles, assemblies and corridors well, the process is pretty painless once you get the hang of it.
Hope that helps! Good luck!
Joel Ritner
C3D Certified Professional
BIM/Systems Manager
Najarian Associates, NJ
wol000
That’s a good process and the way to go, when I build back like that targeting my road centre alignment and Offset alignment edge, the tin starts to zig zag and attached to existing alignment. I can’t even fudge it, by swapping edges and points etc to get round it, I’m going to rebuild it. I have a very sharp turn / radius just before the intersection, which is causing regions to overlap and I believe this has caused the problem
wol000
I figured it out. My corridor has two separate assemblies, one for each side with the alignment added twice, one for left and the other for the right. The vertical baseline on the right was not set to the correct vertical baseline, so it was slightly off. Very silly,
