- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Grading and corridor experts - I seek your help. I am working on the site layout for the solids handling facility at a wastewater treatment plant and have got myself in a mess. I have multiple roads most making non-symmetrical intersections with each other and some with parking areas off of them. Give the layout I opted to use a corridor over feature lines, but I some areas that I'm clueless on to model.
See the circled areas in the attached PDF - how would you go about doing this with a corridor? I can make the links daylight corrected, then there's the C&G. Should I leave these areas out of the corridor and use features lines here? My end goal is a PG surface. (Having and nice corridor for visuals would be nice, but not required).
I greatly welcome any advice or suggestions on how to grade these areas.
Thanks in advance.
D
