Corridor elevation target
george-alexa
george-alexa
I have a problem with one of my corridors. The elevation goes up and down randomly, even if the target it's set corectly.
I've tried using lower frequency, modifying the lenght of the corridor region and i didn't find a solution.
Targets are set for main road alignment and secondary.
Can anyone help me or give me a hint?
wol000
Hi George,
Check your vertical alignment, make sure it starts and finishes exactly at each end on your long section. This might fix it,
Second check, make sure you are assigning the right vertical alignment in your corridor,
george-alexa
Thank you for the answer. I did a checkup and everything fixed. 😄
