Civil 3D Forum
Corridor elevation target issue
4 REPLIES 4
636 Views, 4 Replies
I have offset drainage structures throughout my project. The only way i know to make these lows have the elevation i want is to create a left and right PGL and target the Outside Elevation Target. For some reason, some work and some don't. I added frequency and it fixes some and some it doesn't. I have also check and re-checked the PGL elevations and stations but some of them do not reflect what my right and left PGL lines are set to. Any ideas?
4 REPLIES 4
wfberry
Perhaps I am not following what you are doing.  Don't you have a Final Surface to use as your target?
Bill
in reply to: wfberry
When creating a corridor it uses the assembly right? Well if I have a crown elevation of 18.00 and I want my drainage structures to be 17.80 (2% slope-10' wide pavement) how can you have the corridor read that elevation correctly if the lows aren't perpendicular to the high point in the road?
wfberry
Joe:
Your drainage work (piping) should be done after you have a final surface.
Bill
The pipes were already put in for a Environmental Resource Permit which doesn't require a surface. So the drainage was done up front for this project which isn't a issue as it's easy to tell the structures to look at a surface after the fact. Not to be rude, but the order in which the pipes are added has nothing to do with the result i'm looking for. When creating a road surface generally a designer/engineer already knows where the drainage is going. So without the pipes actually being in the base you would still want to target outside lanes to a right EOP and left EOP to get the result you want if lows are not perpendicular to the high point in the crown of road.
Rail Community
