Civil 3D Forum
Corridor Curb Return modelling
15 REPLIES 15
Message 1 of 16
oguntugasamuel
654 Views, 15 Replies
I am struggling to create a curb return on my intersection and I have tried it so many times it is not coming out well.
I need help on this.
Thanks.
Labels (1)
15 REPLIES 15
Message 2 of 16
nkiakas
in reply to: oguntugasamuel
HI @oguntugasamuel
Can you share your file to take a look?
Message 3 of 16
Joe-Bouza
10 times out 10 the issue is related to targeting. was road3 done with the wizard? What was added to the corridor properties?
Check all targets
Joe Bouza
Message 4 of 16
m_kingdon
I personally don't use the intersection wizard. I find it a bit unreliable. Have you drawn offset alignments and connected alignments?
Mike Kingdon
Civil 3D Zealot
Message 5 of 16
oguntugasamuel
in reply to: m_kingdon
No I haven't, as I said from my post, I am a starter and I was just following the instructions from the training I had which is by using intersection to design the curb return, however, I have seen videos on using the connected alignment but I have not yet that before.
Message 6 of 16
oguntugasamuel
Though, I have my offset alignment for the road width but not the connected alignment
Message 7 of 16
oguntugasamuel
in reply to: nkiakas
Yes sure.
I will be glad to do so.
Message 8 of 16
oguntugasamuel
in reply to: Joe-Bouza
Thanks a lot sir.
I will review all the targets and see if they're all targeting there respective targets.
Note: I am still an amateur on this and willing to learn.
Thanks once again.
Message 9 of 16
EliANewlines
Hi @m_kingdon , you don't use the wizard to create corridors, or you don't use it at all? How do you ensure the intersecting profiles match elevations? I despise the wizard but it seems there's no other way to lock the profiles together
Message 10 of 16
You can add crossing on the target profile or superimposed. I use this option before I known about using intersection
Message 11 of 16
Joe-Bouza
in reply to: EliANewlines
You can manually lock pvi in the layout profile editor. the accurate locking pont can be done with cogo projection
Joe Bouza
Message 12 of 16
Joe-Bouza
Joe Bouza
Tags (1)
Message 13 of 16
oguntugasamuel
Pls sir, can you attach a picture for illustration?
Message 14 of 16
tcorey
Here's a blog post I wrote several years ago. It goes step-by-step through the workflow for creating an intersection manually, without Intersection Wizard.
https://timsc3dblog.blogspot.com/2020/05/corridor-intersection-primer-manually.html
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 15 of 16
EliANewlines
True, but that isn't dynamic to the intersecting profile, is it? I want the side road to update when I revise the primary
Message 16 of 16
Joe-Bouza
I am sure you do want dynamic, but I was answering post #9.
The Wizard isn't as bad as it is cracked up to be. Especially for the geometry in your original post. There isn't anything unusual to it and the wizard should do it easy-peezy.
By the way, the wizard only wants ONE layout profile per alignment. So, if you have more than one the wizard may have a hissy fit
Joe Bouza
Rail Community
