Civil 3D Forum
Corridor Creating a Surface between two Distinct, Separate Regions
5 REPLIES 5
HAGED333
861 Views, 5 Replies
I have a break in my corridor where I'm crossing a road. For example, Region 1 goes from STA 5+00 to 7+00 then Region 2 goes from 8+00 to 10+00. Therefore I have no region between STA 7+00 and 8+00 but a surface is being generated connecting the two regions. How do I break this connection? I have 'Corridor Shrinkwrap' enabled.
Thanks!
5 REPLIES 5
Jeew-m
in reply to: HAGED333
Create a polygon in the area where you need to hide and add that as a hide boundary to the corridor surface.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
neilyj666
@HAGED333 as an alternative to the suggestion from @Jeew-m you could also restrict the triangle length in the surface build properties to say 90' i.e. less than the gap in the corridor
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Joe-Bouza
Set the maximum triangle length shorter than the intersection gap but large enough to take care of the rest
Joe Bouza
HAGED333
in reply to: Jeew-m
@Jeew-m , your solution works the best for my scenario. My follow up with your method is, once I've created the polygon and added a 'hide boundary', the polygon does not seem to be dynamic. Meaning if I adjust the polygon to include more contours, it does not hide them. I've rebuilt the corridor and the surface and even restarted C3D. Is there a way to update the boundaries or do I have to reset them each time? Thanks!
Jeew-m
As a workaround, you can add a hide boundary to the surface through prospector --> Surface --Definition --> Boundaries.
That boundary would be dynamic to your updates.
Jeewana Meegahage
Design Engineer
Rail Community
