Civil 3D Forum
Corridor code set Material Area Fill Style order
4 REPLIES 4
m_kingdon
561 Views, 4 Replies
This is probably a ludicrous longshot, but is it possible to add a drawing order to the material area fill style in the corridor code style settings?
I have built a somewhat complex road corridor that includes different curb types.  I thought I could use the code styles to colour each curb type a different colour using a uniquely named generic link that runs through the subassembly.
This technique ALMOST works.  But sadly the hatch clashes with other material area fills, even if I have the link above the part using verticle links.
Is there a way around this?  Or another way of colouring / labeling parts of a corridor in plan view?
Mike Kingdon
Civil 3D Zealot
4 REPLIES 4
Dandman01
in reply to: m_kingdon
Did you ever get a fix for this? I have a similar problem with the fill that should be on the bottom, bleeding all over everything above it
m_kingdon
in reply to: Dandman01
No, sorry I had to move on.  I deemed this one of those small non critical issues that would be nice to resolve, but probably not worth the time.
Mike Kingdon
Civil 3D Zealot
mmuileboom
Has anyone found a sollution yet? I have the same problem. My corridor shows the sandfoundation from a lower link instead of the concrete from de top link. Is there some kind of 'attribute order' or 'bring to front or above button' to make sure that the style of the top link is always shown above?
Are you using 2024? Did you tried opening the file in 2023? Its probably a bug in 2024.
Rail Community
