Civil 3D Forum
CORRIDOR BOUNDARIES/SURFACES
5 REPLIES 5
572 Views, 5 Replies
Im designing a trench which was created with subassemblies that will be under an existing ditch.
The problem is that I need the excavation shown. When I paste the surfaces the ditch grades up to the top of the trench. I attached some photos of how it looks pasted. It should look like photo 1, but the ditch should be graded like photo 2 continuously so it just drops off into the trench. Both of these are corridors. If i could use a portion of one corridor as a boundary to another that would probably help but im not sure.
I have pasted surfaces
played with the regions
created a tin volume surface and used it as the boundary
5 REPLIES 5
ToddRogers-WPM
The paste order is important.  Did you happen to try and paste it the opposite way you did?
Todd Rogers
in reply to: ToddRogers-WPM
Yes, Ive also tried the TIN volume surfaces both ways
ToddRogers-WPM
I thought you said you were pasting the surfaces?  Pasting surfaces and created TIN volumes are very different.
Todd Rogers
First I tried to paste them, I pasted them both ways.
I also tried to achieve my task with creating a TIN volume surface in which the order matters as well and I tried that both ways and still so solution
ToddRogers-WPM
Rail Community
