Correcting faulty alignment spiral data input
Partenheimer
Partenheimer
We have a 99 segment alignment. At segment 32, a spiral-out, we accidentally entered cw (clockwise) direction instead of ccw (counterclockwise). Does anyone know if this can be corrected?
The best I can think of is to copy the alignment, shorten each alignment to and from the correction point, precisely place the end alignment, and then edit the two together into one.
or
Start over.
Any suggestions are appreciated.
TIA
Dexterel
add your dwg. If you have a solution for CW between to entities, I dont think its possible to have a solution for CCW, without the alignment looking odd.
copper.chadwick
Autodesk Support
Autodesk Support
@Partenheimer,
Great question about a common error in the workflow of creating an alignment. Did you have a chance to resolve this? If so what were the step you took to do so? Please hit the Accept as Solution button if a post fully solves the issue or answers the question.​ Thank you for your participation, your accepting a solution adds value to the post for the community as a whole, and helps other members find answers to their issues.
Copper Chadwick
Designated Support Specialist
