Civil 3D Forum
Copy Corridor
8 REPLIES 8
Message 1 of 9
ebarlevi
1400 Views, 8 Replies
Copy Corridor
How can I copy a corridor in the same drawing.
Thanks.
8 REPLIES 8
Message 2 of 9
klugb
in reply to: ebarlevi
You can't. I have been adding it to the wish list for 2 years now.
If you try to block it out and back in you get two of every alignment & profile & Assembly.
Hint hint,
If one of our third party software vendors that troll the discussion group would ad that feature I think we could justify buying it 🙂
Bruce
Bruce Klug, P.E.
AutoCAD Expert Elite Alumni
AutoCAD Civil 3D Certified Professional
Civil 3D 2023.2.1
Win 10 Enterprise, 64-bit
Message 3 of 9
Hi Bruce,
Just curious. What use would you make of a copied corridor?
Regards
Laurie Comerford
> profile & Assembly.
> Hint hint,
> Bruce
Message 4 of 9
If you are looking to make alternate design scenarios you can add your
baseline again (baseline) clear the check box for baseline, change the
parameters for baseline 2 and compare scenarios.
Message 5 of 9
klugb
The last time I wanted to copy a corridor I had one fairly complete and we decided to look at lowering 1000' of roadway in the middle of a 6000' run.
I wanted to copy the existing and use the new profile in this section. This section was split into 10 different regions and I didn't want to manually change them each time I wanted to switch profiles.
Bruce
Bruce Klug, P.E.
Civil 3D 2023.2.1
Message 6 of 9
Hi Bruce,
Thanks. I must have been in La-La land not to think of retaining an
existing design while trying another similar one.
I think I would have simply made a copy of the whole drawing and tried
the new design in the copied drawing
Regards
Laurie Comerford
> run.
> Bruce
Message 7 of 9
troma
Bump.
Where is that IdeaStation?
Mark Green
Working on Civil 3D in Canada
Message 8 of 9
mathewkol
I agree with Laurie's suggestion to perform any and all alternate designs in separate files. This keeps things more organized with regard to layers and makes the files smaller as there is only one design option per file.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 9 of 9
I have a scenario that being able to copy a corridor would be beneficial. I've got a road corridor that I need to show daylighting to existing grade for the road construction portion of the project and I also need to remove the daylighting and grade up to the proposed building pads for the lot grading portion of the project. Being able to toggle between the two corridors and their surfaces would be great.
Intel(R) Xeon(R) W-2245 CPU @ 3.90GHz 3.91 GHz
64 GB RAM
C3D 2023.2
Rail Community
