Coordinate System Won't Apply
Message 1 of 12
C3D 2016 w/Win7
I try to use set the coordinate system on a fresh dwg with nothing in it using Prospector, Settings tab, right click drawing name, Coordinate System tab. I pick my system. I hit Apply, or OK, and it doesn't work - it immediately clears the coordinate system field and replaces what I selected with No Datum, No Projection.
I imported a point cloud of 1.5 million XYZ points and this stressed my machine out. I restarted C3D, but it didn't help. I have not restarted the machine.
What do I have to do to assign a coordinate system so that it actually sticks?
THANKS
Replies (11)
Message 2 of 12
AllenJessup
Can you do it with MAPCSASSIGN?
It sounds like you may need to do a reboot or even a repair.
Allen Jessup
CAD Manager - Designer
Message 3 of 12
I didn't try the Map command. I *did* do a reboot and it stuck. Importing all those points did my machine in.
I wish C3D could handle point clouds better, especially since data acquisition of massive point files is becoming pretty common. I know that you can use Map to depict surfaces, but only to depict them, not to design from them, or follow water drops, or get volumes, etc. But 1.5 mil XYZ points was more than my very capable machine could handle, I guess.
thanks
Message 4 of 12
Pointdump
D,
Not sure what's happening with your Coordinate System not "sticking". Allen's suggestion of a repair might be necessary.
1.5 million points shouldn't be a problem for 2016:
https://knowledge.autodesk.com/support/autocad-civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticl...
In what form is your data? CSV or LAS? How are you importing your data? When you import points with a CSV file you can "sample" the points to reduce the number. With a LAS file you can reduce the number of points with LASThin, one of the free LASTools programs:
https://rapidlasso.com/lastools/
You can also make up your surface with different densities of points, more dense in your areas of "focus":
https://www.youtube.com/watch?v=GottqJ5r4Cg
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 5 of 12
Another day, same problem. MAPCSASSIGN worked, using drawing settings did not.
I had a comma delimited XYZ file for the surface. I imported them into a surface as a point file. It slowed the program WAY down. I will look at LAS, thanks. but, it seems that how i define points for a surface shouldn't matter - once the points are in there and the surface built it slows.
Message 6 of 12
Pointdump
D,
LASThin is for LAS and LAZ files. For a CSV (comma delimited XYZ) file, sample your points on import.
Please post your drawing and the CSV file. What coordinate system are you trying to use?
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 12
AllenJessup
If you are creating a Surface from a large XYZ point file. Don't import the points. Add the file directly to your Surface.
Allen Jessup
Message 8 of 12
Pointdump
Allen,
My bad. You're right.
"sample your points on import" I should have said "sample your points on ADD"
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 12
AllenJessup
Dave,
It took a long time for that to be pounded into my head. So I feel I should remind others.
Allen
Allen Jessup
Message 10 of 12
That is what I did - add a point file. It slowed down to a crawl. Not just surface manipulation, but everything.
Could our network have anything to do with this? i.e., I'm at the water utility, the servers are downtown.
Message 11 of 12
Pointdump
D,
"Could our network have anything to do with this?"
Dunno. Post your data and desired coordinate system.
Dave
Dave Stoll
Las Vegas, Nevada
Message 12 of 12
AllenJessup
It could. Depends on the connection speed more than the distance. Our server is in another building.
I have an SSD. So I tend to work on larger projects locally and back them up to the server.
What is your computer configuration?
Allen Jessup
