- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am using Civil 3D 2018.
When I select a state plane reference coordinate system for my cad file, I expect the northing-easting values to read from the origin of the projection and datum, as the two should coincide. However, if I place the northing-easting grid in a file without a coordinate reference system set, the northing-easting values still read the same. It seems that by changing coordinate systems from "none" to a "state plane projection", that the origin of the file would move to coincide with the state plane projection, but in my example, the origin remains unchanged. My question which is somewhat academic, is this:
how can N-E values read in a file with no coordinate set, the same values as they would in a different file with state plane coordinate system set?
