Civil 3D Forum
Coodrinate size
6 REPLIES 6
426 Views, 6 Replies
Coodrinate size
Hello All. I have one problem. i want to put coodrinate on DWG and i use add labels. when I put coordinate,than  I want to change size, i changed text size but it does not changes.. What have I to do?   Please help me..
6 REPLIES 6
KirkNoonan
I imagine that you are using a C3D Note for your label. There are many possible reasons for the text saize not changing, but I can tell from your screenshot that the scale of your draing is likely one reason that the texct is so large if this is a C3D note type label. Otherwise, make sure that when you change the text size that you also change the text size on the dragged state tab.
in reply to: KirkNoonan
yes, it changes.  thank you..  but may be there is even more way.. Smiley Happy
neilyj666
Remember that all Civil labels are in absolute size e.g. 3mm so they will be very large (relatively speaking) in a drawing at 1:10000 compared with a 1:100 drawing
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
KirkNoonan
I didn't really explain it very well. In the label style editor, the place where you changed the text size was most likely on the layout tab. Check the dragged state tab to make sure that the text size there is also what you want it to be as that size can be different than the default text sizedragged state.PNG.
in reply to: neilyj666
o.k I understand that that it is very large. this means that there is not other way to change size? Smiley Indifferent
wow... thank you kirknoonan.. I am looking for the whole day.. thanks...Smiley Happy
Rail Community
