Is there a way to convert a 3D solid to a civil 3D structure ?
Solved by stevenh0616. Go to Solution.
No unfortunately there is not a way to do that. Structures in Civil 3D are parametric objects. 3D Solids are not. You'll need to model it in Part Builder or in Inventor to create it parametrically, update the catalog, and then add to a Parts List in your file.
Steve Hill, Civil Designer / .NET Developer / AutoCAD and AutoCAD Civil 3D Certified Professional
http://redtransitconsultants.com/
Autodesk Exchange Store
Twitter | LinkedIn | YouTube
Is it as simple as importing the 3D solid into Inventor and saving it in another format? I have some very complex 3D solids that I need to convert to structures. I want to be able show them in my Civil 3D sections and profiles automatically. For me to do this now with my 3D solids, I have to slice the solid at every section and then project them onto the sections. It's very time consuming.
Thanks, Darren
No it’s not that simple. You have to have the specific parameters available in the inventor model to match up with other parts. Then use Infrastructure Parts Editor to import it and build a list of sizes.
