Civil 3D Forum
Contours vertex to arcs with a minimum radii
10 REPLIES 10
Message 1 of 11
rodrigo_carreras6AB7W
469 Views, 10 Replies
Hello everyone! Is there a way to convert vertexes of a contour to arcs with a minimum radii?
The only way I figured it out is converting every contour to an alignment, and then modifying the alignment's radii.
I wonder if there is another way to do it, to a group of contours, automatically.
Tags (1)
Labels (1)
10 REPLIES 10
Message 2 of 11
Without a picture of what your wanting (and I'm not sure why you'd convert a contour into an alignment) could you be looking for contour smoothing in the surface properties.
Rick Jackson
Survey CAD Technician VI
Message 3 of 11
Type PE on command line.
Then select multiple
Select all your contours
Then select fit from the command line.
You will see all the vertex are now converted into curves.
One thing to note is that now there will be very less/no straight section on the contours
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Message 4 of 11
All Contours are lies. And there’s the proof.
anyway, use MAPCLEAN
Joe Bouza
Message 5 of 11
It looks like you're not working with Civil 3D contours but with polylines representing contours. Is that correct?
Allen Jessup
CAD Manager - Designer
Message 6 of 11
Thank you for your answers.
The thing is that I have this rice farm project. The tractor must have a path that matches the contours of my surface.
The problem is that the countours have vertexes, and I need them to be arcs that have a minimum radii (for example, 20 meters), the minimum to allow the tractor to turn without problems.
I need a method that assures me that all contours will have arcs instead of vertexes, with that minimum radius.
Message 7 of 11
In that case I would extract a contour line, and then convert the contour to an alignment with the radius set to 20m. You'll not get a variable solution, but your minimum radii would be achieved.
Rick Jackson
Message 8 of 11
I tried, but sometimes (I don't know why) the alignment has curves with a radius value that is less than the required (less than the default radius I entered when I created the alignment). I have to go to the geometry editor and assign the value manually.
Also, the problem is that I have several contours, turning all of them into alignments take time.
Message 9 of 11
That's most likely because the contour has something already less than your minimum. That's where @Joe-Bouza mention of MAPCLEAN may assist by removing vertices (weeding) from the contour. The curves in contours are defined by the smoothing factor, there's no control of that since the TIN model is the control. Another option would be to remove all smoothing and then extract the contour and create the alignment with the minimum radii. This would ensure sharp points that would get the radii added.
As far as automating it. That would probably require programing of some type (lisp or dynamo).
Rick Jackson
Message 10 of 11
I would suggest not trying to get contours from the surface to match you design requirement but design the contours and use them to create you surface.
much easier than after the fact
Joe Bouza
Message 11 of 11
Hi @rodrigo_carreras6AB7W
I was wondering why you need to do it...
After your reply with the tractor looks like that, yes you have to do it.
I guess you may have thousands of contour lines.
Regards
Rail Community
