Civil 3D Forum
contour labeling
14 REPLIES 14
Message 1 of 15
CaptainJoFo
951 Views, 14 Replies
contour labeling
In the dwg that I'm in, when I label contours, it is defaulting to turning the label line on and the contours off which is the opposite of what I want. I know how to change this in the properties and end up with what I want but what I can't figure out is why it is initially labeling them this way. I'd like to just label away and not have to go into properties and change the labels every time.  Where do I change the default label set up?
14 REPLIES 14
Message 2 of 15
Jeew-m
in reply to: CaptainJoFo
Usually, you can update the default settings from the settings tab.
Right-click on add contour labeling and go to edit.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Message 3 of 15
CaptainJoFo
in reply to: Jeew-m
I already tried that. I have the styles I want as default. I don't see anywhere to specify where to change display from false to true or vice versa.
Message 4 of 15
CaptainJoFo
Actually I did find where to specify the true/false display for the label line which I set to false. It still displays it as default though. I have yet to find the true/false display setting for the label.
Message 5 of 15
Jeew-m
Can we have an image of what you expect?
Jeewana Meegahage
Design Engineer
Message 6 of 15
CaptainJoFo
I just expect to label a contour and have the label display and the label line not display. The default in this particular dwg is somehow the reverse of that. I label the contour and I see a label line and no contour label. Then I have to select the contour label line and go to properties and set the label line display to false and the labels display to true. Hopefully that clarifies it. I'm not sure what kind of image I would share that would help.
Message 7 of 15
Jeew-m
I also do not see any option. Usually, it comes as true by default.
I hope you use select similar and change properties as of now.
Jeewana Meegahage
Design Engineer
Message 8 of 15
rl_jackson
Setting, then Command settings
PS: @CaptainJoFo, I have looked at this post multiple times and was like dang-it where is that! It's one of those things that you set it and forget it, do this in your DWT and you can forget it too....
Rick Jackson
Survey CAD Technician VI
Message 9 of 15
user181
Hi @CaptainJoFo  for the label visibility edit the Label Style and on the General tab make sure Label Visibility is set to True
Message 10 of 15
CaptainJoFo
in reply to: rl_jackson
Already set to false yet it still defaults to showing the line when they are initially added.
Message 11 of 15
CaptainJoFo
in reply to: user181
Visibility is set to true. Still defaults to not show when labels are initially added.
Message 12 of 15
wfberry
Settings --> Surface --> Contour --> (Select the style you are using) Look for Visibility.
Bill
Message 13 of 15
cwr-pae
Don't edit the command or labeling settings, change the "Surface" settings. This applies to all surfaces. After this you may have to hunt for and change overrides in the sub branches.
Message 14 of 15
CaptainJoFo
After beating my head against the wall trying to communicate the information I needed I found the solution. What I was looking for is driven in the command settings. However it's NOT in the AddContourLabeling, it's in the AddContourLabelingGroup settings.
Message 15 of 15
CaptainJoFo
After further investigation... the above solution works for multiple contours at once. For individual contours the defaults in the AddContourLabelingSingle must be changes as well.
I'm not sure what the point of having these as separate settings from the AddContourLabeling defaults, but it is what it is.
Rail Community
