@jmccollister2YP4N wrote:
1) I am not sure what the default is. How would I determine?
2) See attached picture...
3) Yes I am sure I selected "Inner Diameter"
- What catalog are you editing? Where is it stored and has it been edited before? If it's whatever comes with the software and hasn't been edited then it's the default. That is what Out of the Box (OOTB) means.
- Your screenshot is showing the upper portion that I mentioned before. When you select a part you'll also see on the bottom half of the Content Catalog Editor there are more fields for the Connection Points. Those must also be filled out as well.
- The label is showing ??? because the catalog has no information for Inner Diameter as shown by your screenshot.
It sounds like you're not getting the changes to your catalog saved because it's in a folder that's read-only. You need to make sure you have write permissions to the folder the catalog(s) is in. I recommend making a copy of the OOTB catalogs, put them in a folder you create (either a local folder or on a server that's not ACC), then create your parts list using those copied catalogs. Editing the default catalogs in their install location can cause issues such as write permissions, issues when a new version comes out as the catalog path changes, etc.
C3D 2024-2026
Windows 11
32GB RAM
