- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I was wondering if anybody had found a way to show construction grids (the grid with letters on one axis and numbers on the other commonly used in building construction, aka column grids?) in a dynamic way in profile views?
Here is what I'm tring to accomplish:
Most of the projects I'm working on have a construction grid. Part of our plan production involves making sections at arbitrary paths (these are not always perpendicular to the grid lines) and might turn at certain points (eg. a polyline with multiple vertexes, not just a simple straight line).
I have to manually draw the grid lines in all our sections. This is not that bad when I do it one time but if the "path" of the section is altered I have to start from scratch and position the new locations of the corssing gridlines in my profile view.
What I've trid:
- adding geometry points to my alignment (=section) at the points, where my alignment crosses a grid line and adjusting my profile view style to show geometry points in a different way (if the alignment is changed I have to move the "new" geometry points manually and besides this it is a ****ty work around any way)
- drawing the grid lines as 3d polylines and projecting them to my profile view (by altering styles I can make only the last and first vertex visible when projected on my profile view. Works as long as my section is perpendicular to the grid lines, but if not then it does not work...)
- using blocks and projecting them (also ****ty solution for many reasons)
What I haven't tried:
- using alignments as "grid lines". I believe this could accomplish my needs, but it would fill my drawings with a lot of essentially useless alignments.
What I'm hoping for:
- In projection styles there is an option for sections only to show the "crossing vertex". If this would be an option when projecting things on a profile view this would probably solve my problem. Something like this would be what I'm looking for...
- I would also like the labeling to be dynamic, so that the grildine ID (eg. "A" or "8") would be automatically displayed (I think this would be possible if I used feature lines (they are given names, and hence the dynamic labeling ought to be possible)
- Anything that accomplishes my needs...
If you have some trick up your sleeve I would love to hear of it!
- Frans
PS. I'll attach an picture of the "construction grid" in case it is unclear what I'm referring to.
