Computing materials each material with a different units
hema.sourour1
hema.sourour1
  1. Hello everyone,
I'm using civil 3D since a while i have no problems with that. Computing materials in default is in ( m3) for all materials.
For example, I usually compute fill/cut, base, asphalt and concrete as well, all units are in ( m3 ). If i want asphalt for example in ( m2 ) then i have to divide it's quantity by depth.
In my current project it was refused to do like this. It was asked to get each element with it's unit directly from civil 3d
Is there is anyway to do that ?!
I'm sure there must be away.
Finally i need
* Curbs in (m)
* Asphalt, slope protection and rigid pavement in (m2)
* Fill/cut and base (m3)
hema.sourour1
any one can help !!
andrewpuller3811
You can use the quantity take off manager to assign pay items to lines, polylines and hatches to get quantities for linear objects and areas.
Check here - https://help.autodesk.com/view/CIV3D/2021/ENU/index.html?guid=GUID-5FF56BE5-46CA-4B9F-A4CD-BCFE6F6C8...
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
lim.wendy
Hi @hema.sourour1 ,
Welcome to the Civil 3D forum. Thank you for submitting your question in our discussion forums. Have you had a chance to look over the suggestion provided by Andrew?
Do you have any questions about it, let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
