Civil 3D Forum
Compute material is not computed properly in cross sections
13 REPLIES 13
Message 1 of 14
1102 Views, 13 Replies
Hi.
i compute materials and most of cross sections are computed. But some of them aren't computed completely.
Can i hatch manually and it gets added to the volume ?
You can see what i mean in the two pics
13 REPLIES 13
Message 2 of 14
cwr-pae
Pics not attached. But no, you can't hatch the section manually and have it add to the quantities. Hopefully the solution is easy once we see the pics.
Message 3 of 14
in reply to: cwr-pae
here you are
Message 4 of 14
Sorry i had a problem in uploading here you are now
Message 5 of 14
madhu_konga
check the surface in object viewer is it build proper, if not use future lines as a surface break lines with point codes.
Message 6 of 14
in reply to: madhu_konga
I guess the surface looks fine in the cross section
Message 7 of 14
madhu_konga
send your file for better understanding, Let me check what is the problem.
Message 8 of 14
Here it is
Message 9 of 14
Still my problem hasn't been solved
Message 10 of 14
cwr-pae
I spent around 3 hours poking around in your drawing with out finding a complete solution. I do have some suggestions that may help. If I understand correctly you are removing material to make the cut surface, then building the canal structure and side fill on that surface to follow the expected construction process.
Instead of using multiple surfaces to determine your volumes for your 2 fill surfaces paste the G.L, Cut and Structure surfaces to a single surface for your lower surface in the materials list. This will simplify the sections and maybe fix the problem. Note you an still show the G.L, cut and structure in the section view, just don't use them in the materials.
Message 11 of 14
Yes sir. You are right about that i will cut first , build the structure then refill on the both sides.
So how can i merge the 3 surfaces and when i target how will it target the cut surface not the G.L
Message 12 of 14
And i am sorry that you spent all this time to find the issue and is it a common issue happens with ppl or it just happens with me ?
Message 13 of 14
Joe-Bouza
Not you. Happens to all of us from time to time. modeling process can put blinders on us and we don't see the trees in the forest
Joe Bouza
Message 14 of 14
cwr-pae
Create a new blank surface, under edits in the prospector tree is the command paste. After pasting go to surface properties, definition tab. Make sure the cut surface is on the bottom. See images:
Rail Community
