COMPARING POINTS TO SURFACE
caddirt
caddirt
Is it possible to generate a report comparing the point elevations of one surface to the elevation of the surface either above or below it?  I'm hoping it is something I haven't found yet and not an add on.
brian.strandberg
For comparing two surfaces, the easiest is to create a tin volume surface, the elevations of which will represent the difference between the two.
This doesn't line the points up exactly.  If you needed to do this, I would probably create a point group to represent all the points in surface 1 and use project explorer to compare to another surface.
You can extract points from a surface fairly easily, as long as the points are displayed in the current style.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Joe-Bouza
Create a UDP and assign surface 2 to it
export to excel or table
Joe Bouza
lim.wendy
Hi Marc,
Thank you for submitting your question in our discussion forums. Have you had a chance to look over the suggestions provided by our experts?
Please let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
