COMPARE AECC OBJECTS
21127015
Message 1 of 11
21127015
I’ve tried using the COMPARE command, but it doesn’t seem to detect changes in Civil 3D object data (e.g., surface elevations or label of pipe network, label of aligments).
Is there a better way to compare these objects between two files?
Replies (10)
Message 2 of 11
ianjchap
Hi @21127015,
Comparing data between two different Surfaces is always best to understand in Profile or Section view.
Ian Chapman
If you found this post useful, please Like the post.
If this post helped you successfully solve your problem, then click on the ACCEPT SOLUTION button.
Message 3 of 11
21127015
I’m looking for a way to compare two labels, such as pipe network labels or surface spot elevation labels, between two Civil 3D drawings.
Message 4 of 11
AdammReilly
COMPARE is an AutoCAD command and doesn't fully work with the verticals built on AutoCAD.
If you're looking to compare things like labels, the best (or worst) way to do this is explode the data in the two files (obviously saving to a temporary location for this) and then compare those files once the C3D data has been destroyed/converted to AutoCAD entities.
At that point, COMPARE will work to find you all the things.
Adam Reilly
Civil App Developer | AMR Consulting
Civil 3D 2026/2027
Creator A16 AI+ A3HVFG
Windows 11 Pro
AMD Ryzen AI 9 365 w/ Radeon 880M
LinkedIn
Group Leader badge
Austin CADD User Group
LinkedIn | Discord
Civil 3D Certified Professional
Message 5 of 11
pkomatlapalli
Hello @21127015
Just checking in—did the responses shared by @ianjchap and @AdammReilly  help clarify your question?
If so, please consider clicking the "Accept Solution" button on the post(s) that solved your problem. Doing so helps others in the community easily find useful answers.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Pavan Kumar | Community Manager
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot.
Pavan Kumar
Message 6 of 11
21127015
Hi @pkomatlapalli
I still haven’t received a solution for this yet. Could you please update me?
Thank you!
Message 7 of 11
ianjchap
Hi @21127015,
Create a Profile view, add both surfaces and look at the profile view to compare.
You can move your alignment position around to compare across the surface. Any difference would be noticed in the profile view.
Ian Chapman
Message 8 of 11
ianjchap
As a snap shot, you could look and compare the Statisics of the two surfaces to see some broarder information. If you're looking to understand if thet are different. This will tell you straight away.
Ian Chapman
Message 9 of 11
21127015
Hi @ianjchap
No, I think you misunderstood my point.
What I mean is comparing labels and notes of objects that are associated with AECC objects.
Message 10 of 11
AdammReilly
As I pointed out earlier, there is no way to do that with AECC objects - at least not with the OOTB compare command. That's an AUTOCAD level command and doesn't reliably recognize CIVIL 3D objects.
The best way to compare those things is by dumbing them down to AutoCAD entities - through the use of EXPLODE. I don't like this method because it's so destructive but it will get you what you're looking for through the means you want to see them.
Adam Reilly
Civil 3D 2026/2027
Windows 11 Pro
LinkedIn
Group Leader badge
LinkedIn | Discord
Message 11 of 11
pkomatlapalli
Hi @21127015
Did the info from @ianjchap and @AdammReilly  help answer your question?
If it did, it’d be great if you could click the "Accept Solution" button so others can easily find it too.
If you’re still needing more help, feel free to share an update here. The community will be happy to jump in with any next steps to help you get where you need to be.
Best,
Pavan Kumar| Community Manager
Pavan Kumar
