- Mute
- Permalink
- Report
I'm working in Civil 3d 2019. Has anyone had an issue where you are working w/ the command line dialog (not attached to your cursor) and life is good for a substantial period of time and then all of a sudden, anything you type fails to show up in the command line? I've found you can click on the tab of another open drawing and switch to it and then come back and miraculously you can type in your prompt once again. Usually to save it! But this will continue to happen randomly until you close the dwg and then re-open it. Then maybe after an hour or so working in it, the same symptoms may show up again. Really frustrating on so many levels. Thoughts anyone?
Link copied
