Civil 3D Forum
Command Line
21 REPLIES 21
Message 1 of 22
ToddRogers-WPM
2178 Views, 21 Replies
Command Line
It's really a shame that for a few years now, I have to physically dock my command line every time I open the software. Why can't this be fixed? It used to work.
Todd Rogers
21 REPLIES 21
Message 3 of 22
I agree with @cbenner on saving your workspace.  I've been using my commandline docked for years without any issues.  I tried the floating command line, but that one release that had the bug that shortened it every time you opened the software convinced me to leave it docked full width.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
Message 4 of 22
pendean
in reply to: ToddRogers-WPM
No issues at all here if you are talking about AutoCAD (going back many versions): is this a multi-monitor setup?
Not manually saving workspaces?
Not utilizing LOCKUI?
Have a startup resetting everything for you?
Message 5 of 22
kpblc2000
in reply to: pendean
Maybe you have to change WSAUTOSAVE system variable?
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Алексей Кулик aka kpblc | Aleksei Kulik aka kpblc Facebook | LinkedIn
autolisp.ru
Техническая поддержка программистов Autodesk в СНГ
Библиотека пользовательских lisp-функций | Custom Lisp-function library
Message 6 of 22
ToddRogers-WPM
in reply to: kpblc2000
Always...
Todd Rogers
Message 7 of 22
ToddRogers-WPM
Gonna test the LOCKUI. I'll update tomorrow.
Todd Rogers
Message 8 of 22
"Automatically save workspace" is a no-go for me.
Reason ... if you have issues you overwrite a good workspace with the errors.
I only save my workspace manually to make sure it's a valid state.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 9 of 22
pendean
in reply to: Alfred.NESWADBA
>>>...I only save my workspace manually to make sure it's a valid state....<<<
Same for me.
Message 10 of 22
C3D_TomR
I only save workspace changes manually as well.
Tom Richardson
Autodesk Certified Professional in Civil 3D for Infrastructure Design
Autodesk AEC Community Blog
Crossing the line with Civil 3D
Twitter | LinkedIn
Austin CAD User Group Resources
Blog | Discord | LinkedIn
Autodesk Group Network Leader
Message 11 of 22
chriscowgill7373
in reply to: C3D_TomR
I set my workspace up on day one save it and never touch it again until the next year's release.  I wish I could migrate it to the next year's release, but C3D doesnt support migration.  Luckily it is pretty minimal.  Dock the command line and have certain palettes docked and auto hidden.
Message 12 of 22
wfberry
Todd:
If you are still in need of a fix.
After trying for several weeks to get the command line to stay put, I finally used this method:
https://resources.imaginit.com/autocad/command-line-will-not-stay-docked
It is the second article on this page.
It has been working "perfectly" for several weeks.
Bill
Message 13 of 22
ToddRogers-WPM
in reply to: wfberry
Worked like a charm @wfberry! Thanks!!
Todd Rogers
Message 14 of 22
wfberry
You are welcome!
It has sure saved me a lot of grief.
Bill
Message 15 of 22
bzismann
I was running into a similar problem after installing C3D 2022.  Command line would not stay docked.  Checked WS settings - fine.  Checked, restored, reimported profile - still no solution.  I got to thinking - I still had C3D 2018 installed when I installed 2022.  After reading Ryan Wunderlich's article, I went to appdata/roaming/autodesk and there were remnants from 2018 that had not been deleted from uninstall.  I renamed any folder older than my new install data (rather than delete) and reran C3D.  Some folders were recreated after firing up and the command line has stayed put.  I would recommend that an uninstall and clean up is done before installing or that you search for remnants of the old install and try the method that succeeded for me.
Ben
Ben Zismann
Message 16 of 22
Gonna try this in the morning!
Todd Rogers
Message 17 of 22
bzismann
Scrap that idea... opened C3D this morning and command line was undocked again....
Ben Z.
Ben Zismann
Message 18 of 22
Yeah, didn't seem to work for me either. 😡
Todd Rogers
Message 19 of 22
bzismann
Ok... tried something a little different.  Wunderlich's article says to replace the text in your appdata.  I'm calling to a specific profile on our server, which I opened in Notepad.  I searched for "CommandLineControl", which is nearly at the bottom and it doesn't have the text that he specifiies.
So, I replaced it all with his text and saved the .arg file.  Reopened C3D and the command line is docked at the bottom.  Close, reopen, still good, Check the .arg file and text is still there!
If you don't hear from me again, assume that this solution continues to work!
Ben Z.
Ben Zismann
Message 20 of 22
It's really a shame we have to do all of this just because Autodesk refuses to fix this. SMH
Todd Rogers
Rail Community
