How to combine that corridor?
Its really hard to tell from that image exactly what is going on. I have always wanted the ability to easily merge corridors, but it isn't in the software yet.
If you can post your drawing, I can take a look at it, but I would need a bit more information about what you are doing.
Hi Brian thank you for your response. So, this is the drawing, you can see clearly there's two corridors (Main Road and Local Road), my goal is to connect both slopes, but I don't know how to do it. Maybe you have a better solution for this problem.
Sounds like you Ned to blend local to main.
Use FG main as the daylight target for FG local.
FG composite: paste FG main and FG local. In that order
Joe Bouza
Video of CTC Merge corridor in action. 3 different corridors into one single corridor
Thanks @RobertEVs, this is a definitely do-able function. I try to educate our users that there is typically no reason to create more than 1 corridor, this would be a great nice to have function.
