Hello!
Does anybody know of an efficient way to rapidly create COGO points on the intersections between a specified corridor feature lines and created sample lines?
I've tried a lot of things and I just can't seem to find an effective way. I've tried manualy creating points on the intersections, I've used "divide objects", "measure objects" methods of creating points (not very effectively because they are not on the same position as sample lines even if I set the correct incremental step (20m for example)), I've tried creating COGO points from a corridor (but they are connected to the region frequency and thus not very usefull since I have different frequencies in different regions) etc.
Anybody know a solution?
Thank you!
Anton
Are you looking for a static ord dynamic solution, when placing the points? Perhaps you'll find some assitance in the civil customisation forum.
https://forums.autodesk.com/t5/civil-3d-customization/bd-p/190
What is the purpose of these points?
Preferably dynamic, but static is also OK. The point is to create points fast and efficient without a lot of manual work.
