COGO POINTS NOT CREATING
jbaldeo
Message 1 of 15
jbaldeo
Hi, I am trying to create some cogo points but nothing is showing up. I went into Points - create points - manually- I gave it a name and description and elevation but nothing shows up, any ideas ?
Replies (14)
Message 2 of 15
tcorey
Check the Point Group Properties. Set the needed style on the Information tab and then check the Overrides tab. Be sure you specify your styles here, too. Of course, check the layer to be sure it's on and thawed.
Lastly, this could be caused by your Point Group display hierarchy. If a group that is set to no display (and includes all points) is above your group in the display list, yours won't display. You can check layers until you're blue in the face...
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 15
jbaldeo
I checked everything that you requested but it still does not create any points
Message 4 of 15
Pointdump
Hi Jaikaran,
In addition to the excellent advice from @tcorey, check to see if the points are being created. Right-click _All Points and click "Edit Points...". That will tell you if you have a creation problem or a display problem.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 5 of 15
jbaldeo
There are no points created and I tried a few times
Message 6 of 15
jbaldeo
It goes through the motion and ask me all the questions, which I answer, but it does not create a point
Message 7 of 15
Pointdump
Jaikaran,
How about some screen shots of how you are creating points? Or detailed step-by-steps.
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 15
jbaldeo
ok, my main points file is at the top of the list, then I select points - point creation tools - create points bar comes up, I then select manual at the extreme left and it ask for a location, then a name, then a description and then an elevation but it does nothing after that
Message 9 of 15
Pointdump
Jaikaran,
"...then a name, then a description and then an elevation..."
A screen shot please. Click the chevron and expand the Points Creation section. "Name" is usually <None> by default.
Your command line should give you a Northing and Easting if the point creation was successful. Copy/Paste your command line after an attempted point creation.
Dave
Dave Stoll
Las Vegas, Nevada
Message 10 of 15
jbaldeo
Hi, I just wanted to share my findings. I found out that the reason the point was not creating is because I have to change "Point Identity" Next point number to the next number to be used in my file list
Message 11 of 15
Pointdump
Jaikaran,
OK, good to hear! So the next number was already in your All Points? Go ahead and mark your post as the "Solution".
Dave
Dave Stoll
Las Vegas, Nevada
Message 12 of 15
chirag_aggarwalEY78H
Observer
Observer
Thanks for the solution, it was helpful for me.👍🙂
Message 13 of 15
cobusvdm
Thanks, worked for me too
Message 14 of 15
charlie_niu
Observer
Observer
thank you! you saved my day!
Message 15 of 15
pmateoQ7H8P
This issue happens to me constantly. I change the point number to one far from any existing point (example: say points are sequentially 15501 etc... I change it to 25000) and starts creating them. Would like a simple answer why this happens from Autodesk.
