Hello everyone,
do you have any idea how to create COGO points from featureline using the starting station option?
When I use this option using command below I have still COGO points from 0 station.
To Create Points on an Object Using Distance Intervals
https://knowledge.autodesk.com/support/civil-3d/downloads/caas/CloudHelp/cloudhelp/2018/ENU/Civil3D-...
I'm not sure why the start & end stations options are included in the command.
No matter what is entered for a start and end station, it always results in Points being placed at
the specified interval from beginning to end of the Feature Line.
Unless I'm missing something, none of the valid objects listed for use with Command:_AeccCreatePointMeasureObject Select an arc, line, polyline, lot line, or feature line:
can even contain a "station value".
Your workaround sounds like a good option: Break the feature line at the point where you want the "stationing" to begin then join it back to the original feature line and remove the PI if necessary once you've added the points along the feature line.
I tested the workflow you described and got the same result you did: The start and end station selection points were ignored and the points were placed along the full length of the object. This could be a command that's working "as designed" but asking for a start and end point (station) implies that the points should be placed between the two selected points.
Tom Richardson
Autodesk Certified Professional in Civil 3D for Infrastructure Design
Autodesk AEC Community Blog
Crossing the line with Civil 3D
Twitter | LinkedIn
Austin CAD User Group Resources
Blog | Discord | LinkedIn
It appears to use the start and end station to work out the length oddly enough, and relies on you knowing.
If you have a 100m line and put in the values:
Start 20
End 80
Offset 0 (or whatever)
Interval 10
You get 6 points for the first 60m.
In fact if you say start at 20, the offered default end station is 120 so it's not reading the line length at all.
With the Measure Command (AutoCAD) you could put in the segment length only and it started at the first segment end (i.e. the first point appeared at 20m, not at the start)
So my thought, for what it's worth, is that the command is doing what it's designed to do, but not how we would like it to do.
A more pressing question for me is, why haven't I noticed this before? Is it a change from previous release or has it always been this way? I use the command a lot, but usually want a point at the start so have not noticed (I think).
I'm having the same issue. Has there been any other work around for this?
Actually, the ending station is adhered to when I try it Civil 3D 2020. For example, I want to put in the first 3 points spaced at 20 meters, then the next 7 points spaced at 30 meters. So if I run the create points by measure object, I select the starting station as the default start station and ending station slightly larger than 40 meters (if I have it exactly on 40 meters, it seems the last point doesn't get added). So if I do that, then the first 3 points come in great. But the next 7 points start at the default start station and not the value that I enter (let's say 40).
There's got to be another way to do it... I don't want to do it manually, as I need the true distance along the feature line and not the projected distance (i.e. if I was to offset lines at 20 meter and 30 meter intervals, those would be offset on a projected plane, and that error would cumulatively propagate and would be off by about 0.5 meters at the end of the feature line).
