Codes set styles per subassembly solid fill labels
- Mute
- Permalink
- Report
Hi This is a attempt at using subassembly with the goal of not using solid fills with text in the subassembly to label materials on section viewer and section plot aspahlt will be 2.0% or greater the same to subgrade.
Red is to be the datum to which PAY excavation is calculated to using gps machine control the dotted line is a offset to make sure +- excavation is deep enough.
Of course the is not a GPS excavator/operator that could docould do it but there the neet limits a start...of course Blue is the top finnished product.
The colour 251 are intermediate surfaces using 251 to lessen the visual impact. I know the assembly is non functional looking at the way i dragged subassemblys around but the work flow is look at the finish (End Product) assembly and then try to find the start. can code set styles be applyed to individual subassemblys to get the appearance of of the atached jpg.
It seems that one code set can be applied to one assembly ? Maybe there is a way to save basic lane as sidewalk with 19mm gravel base say call it Sidewalk_base.net so code sets can get the easy on the eyes section with out he solid fills or hatch by using text say 100mm 19mm- in place of solid fills/ hatch. TIA
Any one like to post a basic dwg with there solution using basic lane as sidewalk etc varoius levels of material a sort of basic lane does all with a bit of renaming. Thanks again Pete
