Civil 3D Forum
code set style
5 REPLIES 5
M_c3d
482 Views, 5 Replies
code set style
In Civil 3D 2017 if you change the corridor code set style it make no difference when creating the corridor.
For example if i change the default style under the createcorridor command to 'Lightweight 3D View' it still creates the corridor with code set style 'Cross Section - Hatching'
is there any fix to this?  If i delete the code set style 'Cross Section - Hatching' it simply defaults to another one, but no the one its meant to be.
5 REPLIES 5
Jay_B
in reply to: M_c3d
That's the Corridor Style to be used.
To set the Code Set Style to be used, change it in the Feature Settings or Command Settings for CreateCorridor.
Settings tab of Toolspace > rt. click on Corridor > Edit Feature Settings > Default Styles > Code Set Style.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
M_c3d
in reply to: Jay_B
I've already set it in there, it has no affect on new corridors, it seems to ignore this setting
tcorey
in reply to: M_c3d
I am seeing the same (mis)behavior.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
M_c3d
in reply to: tcorey
thanks for confirming the problem.
Any Autodesk watching that can find a fix to it?
lim.wendy
in reply to: M_c3d
Hi Michael,
Thanks for reporting this. This has been an ongoing issue and a case has already been logged with our Development Team.
I apologize for the inconvenience. The only way to change the style currently is to manually change it after the corridor has been built. Smiley Sad
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Customer Value Hub
Rail Community
