Code Label Issues
Code Label Issues
ecursonmsmm
Message 1 of 12
Code Label Issues
ecursonmsmm
My first issue is labeling the links and points of a LinkSlopesBetweenPoints. I cannot find what name if there is one for this subassembly. I can label them by seting the default to a label but this labels more than I would prefer.
Second issue is if you hold CTRL on a Code Label and move it to a dragged state is there any way to reset this?
Replies (11)
Message 2 of 12
fcernst
These are the Codes to work with..
Fred Ernst, PE
C3D 2027
Ernst Engineering
www.ernstengineering.com
Message 3 of 12
RobertEVs
Second issue. Right>click on a code label and reset.
Message 4 of 12
TJMaust
Unfortunately that subassembly doesn't actually expose codes to edit. The link are Top and Datum, as point out by fcernst. But you can't edit those in the code set style dialog box, the image above is from a fresh corridor where I "import" the codes from that subassembly and as you can see...nothing.
Message 5 of 12
ecursonmsmm
If I put any of those in p2, p3, l1, l3 ... none of them label.
Message 6 of 12
ecursonmsmm
I wonder why I don't get that pop window.
Message 7 of 12
fcernst
Label the codes "you have to work with' here and they will show up..
Fred Ernst, PE
C3D 2027
Ernst Engineering
Message 8 of 12
ecursonmsmm
Thats what I thought. This should be resolved for all default subassemblies. I cannot even get this subassembly into the composer to add labels as it is buried in the C3DNETSubassemblies Imperial.pkt which you cannot open. Does anyone know how this is created so I can recreate it for future use.
Message 9 of 12
ecursonmsmm
You must not have CTRL clicked the labels to get that popup. I was under the impression that you needed to have that particular label selected to reset it.
Message 10 of 12
TJMaust
Open the .net file in visual studio, feed the code to AI and see if it can add any links to it, not sure it'll work but its worth a shot if your desperate enough
Message 11 of 12
ecursonmsmm
I found a possible work around but this just seems like a bad coding. Need to give control to the users when using these subassemblies.
Message 12 of 12
RobertEVs
No. Ctrl>Click will only drag it. You have to bulk reset code labels to get rid of the drag one just one.
