Clear corridor bowtie function creates weird links
I'm trying to use the clear bowtie function on a corridor that's daylighting to a surface, but every time I use it, I get this "lasso". What's causing this? The sub-assemblies I'm using are standard civil 3d sub-assemblies.corridor before.pngcorridor after.png
Mike.M.Carlson
Based on your shared pics, it looks like you have an interior corridor radius that is too tight with too long of a side slope daylight for the bow tie cleanup command to resolve it.  I'm not sure a consistent daylight side slope could be maintained perpendicular to your interior ETW in this area given this corridor geometry.  I would treat this tight corner as a separate region and try to transition the interior daylight slope through the curve with the help of offset and elevation targets.  Sorry no simple fix.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
I managed to fix it by drawing a feature line from the the point where my daylighting intersects to the center of the curve of my ditch, then I targeted this feature line.
