from looking at the attached screenshot, the grading cut the corner and did not finish contours around the corner. I started adding points however, it would take hours to add that many points. you can see the grading feature line around the outer corner, just the points did not travel around the outer curve.
Thoughts on how to get the points to travel around the outer curve?
Solved by ecfernandez. Go to Solution.
Hi @BradOatOlsenPerformance a "grading transition" might work. Try it
I hope this helps!
Best regards!
Now the other side of the pond is cutting off the contours.....thoughts?
