Clean Contours or Surface From Drone Data
Hello, I flew a hillside and processed the images in Pix4D Matic and Survey. I then exported both a TIN (LandXML) and Contours (shp).
The TIN is extremely pocketed and not smooth as I would have hoped (see images 1 & 2). The 2nd photo shows my TIN data on the left with little pockets everywhere next to USGS LiDAR data on the right which is smooth as a baby bottom.
The contours are very erratic (see images 3 & 4). There will be 7 contour changes over a distance of 1 ft etc. Then when viewing the surface (Photo 4) it looks like a whole ton of layers stacked on top of each other.
I have both Simplified and Smoothed surface to 100% of points removed, but not much changes. Is there a way I can say have no vertical changes of y height over x distance or something? Or will this have to be reprocessed with less detail in the drone program (Pix4D)? I want to have the surface detailed enough that I can pick out small drainage channels, but not to the degree that it creates this kind of havoc.
Thank you
Contours from exported TIN via LandXML
Pocketed surface on left next to LiDAR data from USGS on right
Contours exported from Pix4D with many erratic changes in short distance
The surface from the TIN with so many changes and layers
