Clean Contours or Surface From Drone Data
SCrispV2HMC
SCrispV2HMC
Hello, I flew a hillside and processed the images in Pix4D Matic and Survey. I then exported both a TIN (LandXML) and Contours (shp).
The TIN is extremely pocketed and not smooth as I would have hoped (see images 1 & 2). The 2nd photo shows my TIN data on the left with little pockets everywhere next to USGS LiDAR data on the right which is smooth as a baby bottom.
The contours are very erratic (see images 3 & 4). There will be 7 contour changes over a distance of 1 ft etc. Then when viewing the surface (Photo 4) it looks like a whole ton of layers stacked on top of each other.
I have both Simplified and Smoothed surface to 100% of points removed, but not much changes. Is there a way I can say have no vertical changes of y height over x distance or something? Or will this have to be reprocessed with less detail in the drone program (Pix4D)? I want to have the surface detailed enough that I can pick out small drainage channels, but not to the degree that it creates this kind of havoc.
Thank you
Contours from exported TIN via LandXMLContours from exported TIN via LandXMLPocketed surface on left next to LiDAR data from USGS on rightPocketed surface on left next to LiDAR data from USGS on rightContours exported from Pix4D with many erratic changes in short distanceContours exported from Pix4D with many erratic changes in short distanceThe surface from the TIN with so many changes and layersThe surface from the TIN with so many changes and layers
Pointdump
Hi Steven,
Your data is too dense.
ReCap will thin points, either by percentage or number of points, with >>>Intelligent Decimation<<<.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
SCrispV2HMC
Unfortunately I don't have ReCap and I don't know if my employer will pay for it. Maybe I'll try the free trial, but would need a solution for the future.
Thank you
neilyj666
@Pointdump I found the recap decimation was a bit confusing first time I used it as the percentage is how much data is to be retained rather than removed—as it is in the Surface Simplification in Civil 3D—I entered 85% and so my cloud hardly reduced in size..!!!
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Pointdump
Hi Neil,
"...a bit confusing..."
Yup. I have a big problem with a lot of the terms in ReCap. Like the term "decimation", which means one-out-of-ten, not however much you key in. I think "thinning" would have been more appropriate.
But don't get me started. 🙂
Dave
Dave Stoll
Las Vegas, Nevada
neilyj666
@Pointdump totally agree
