Civil 3D Forum
CIVIL3D-INTERNATIONAL FOOT TRANSFORM TO US SURVEY FOOT
2 REPLIES 2
CADEngr2014
401 Views, 2 Replies
I was given survey data such as contours, breaklines and spot elevations.   The coordinate system was NAD83 International feet.  I did a coordinate transformation to NAD83 US Survey Feet.  The method I used to transform the coordinate was using Map 3D funCtionality inside Civil 3D.  My workflow was to attach the international foot coordinate file to the US Survey Foot file thru the MapWspace dialog, then perform a query for "all" and execute querry.  The file graphics imported, The points I will treat separately as some ar blocks and LDD points, etc.  Is the above described workflow a legitimate way to transform an International Foot file to a US Survey Foot file?
2 REPLIES 2
tcorey
in reply to: CADEngr2014
Yes.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
CADEngr2014
in reply to: tcorey
Is there a quick way to accomplish a transformation such as insert into the coordinate correct drawing?  What about objects such as surfaces, alignments, etc?
Rail Community
