Civil 3D Forum
Civil3D fonts missing
5 REPLIES 5
Paul-Claudiu_Frona
286 Views, 5 Replies
I would be very grateful for any assistance you can provide regarding the correct fonts to use for the following:
SW1A_DACH.shx
SW1B_DACH.shx
SW2A_DACH.shx
SW2B_DACH.shx
DIN2425.shx
I would be very grateful for any insights or recommendations.
Tags (1)
Labels (1)
5 REPLIES 5
Those font files are not standard OOTB acad fonts/shape files. You'll need to get those from the source or use different fonts.
Rick Jackson
Survey CAD Technician VI
They may be included with a Civil 3D Country Kit. Try the Germany Country Kit.
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/6CinILJfv95QEPUYXxbwud.html
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Dear Sir,
I would like to thank you for your solution. Could you possibly let me know where I might be able to find such databases of fonts?
Dear Sir,
If the drawing came from an outside source, then I would check with that source to see if they can provide the fonts to you. If it was created in-house then you'll need to hunt down the creator to see where those fonts are located, so that they can be added to the standards.
Note: Etransmit zip files generally have the fonts included.
Rick Jackson
Rail Community
