Civil 3D Forum
Civil3d Drawing units INCHES
5 REPLIES 5
Maciej_Lengiewicz
1542 Views, 5 Replies
I have received a drawing from the client, it is a piece of topography and I am positive it is in inches.
Interestingly under Drawing Settings -> Units and Zone -> Drawing Units there are Inches available. I have never seen that before. I thought the only units you can work in Civil3D are meters and feet, right?!Anybody?
I work in Civil3D 2018. Screenshot attached.
5 REPLIES 5
Hi @Maciej_Lengiewicz, you are totally correct, you can only work in C3D in feet or in meters by default, but if the drawing was created in regular AutoCAD in inches then you will be able to see inches as unit options under the drawing settings.
Hope this will help!
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the LIKES button
Tatiana Machado
BIM Manager/ Autodesk Certified Instructor
Blog | Twitter | LinkedIn
InfraWorks Ambassador
Thank you Tatiana!
m.
You are welcome!
Is my please to help!
Tatiana Machado
No, changing drawing setting into feet and even changing units into feet using unit commend also did not help for me. any suggestion?
Pointdump
in reply to: rabinZ3TZE
Hi @rabinZ3TZE,
Try using Command -DWGUNITS.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Rail Community
