Civil3D Command Setting Defaults Issue
jfreeseFVLGU
Message 1 of 8
jfreeseFVLGU
Hello C3D community,
I am currently editing our company templates to change defaults of different commands such as CreateAlignmentEntities, etc to our own styles rather than Standard. The issue is every time I change something in the template, save, and reopen all of my edits are gone. How can I get these changes to stay in my template?
I have attached our template for reference
Replies (7)
Message 2 of 8
VincentSheehan
It seems to be hold for me. Where is your DWT located? Server or local workstation?
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Message 3 of 8
matt_anderson_pe
Make sure your Civil 3D Profile points to that file...
Matthew Anderson, PE
Inundar, LLC
https://wettingthewhetstone.substack.com
Message 4 of 8
jfreeseFVLGU
It is on our server. So maybe that is an issue. I will test on my personal computer real quick. Would you happen to know why that would be causing this issue?
Message 5 of 8
matt_anderson_pe
Do you have permission to save the DWT to that server location?
Inundar, LLC
Message 6 of 8
rl_jackson
When I opened your DWT it had changes made to the command setting for the CreateAlignmentEntites changed already. Are you loading the corrected dwt file.
Rick Jackson
Survey CAD Technician VI
Message 7 of 8
jfreeseFVLGU
I am able to save the DWT in the server file, as I have built these templates from basically scratch. I did notice though when I loaded my DWT onto my personal computer the overrides are applied... This also is not the first time this has happened, as I changed these before without realizing the changes "never saved". It must be getting stored somewhere though if it applys on my PC
Message 8 of 8
jfreeseFVLGU
So I came back to the office today (was working remotely before) and the default styles are now applied... sorry for the confusion; not sure what was going on yesterday.
