I've recently switched to Civil 3D 2012, and after I close the program I get the attached error. It's just a yellow triangle with an exclamation point... Anyone know what causes that and how to fix it?
Do you have (or have you ever had) any 2013 products installed? Including betas?
I tried looking for a post on this, but couldn't find anything other than Fatal Errors, of which this appears to not be.
I get this every time I close down 2012
neilyj (No connection with Autodesk other than using the products in the real world)
Here's a link to the thread I mentioned:
I remember reading something that indicated that 2012 will do this after 2013 is installed. But obviously there is more to it than that. I used to get the "!" dialog, but now mine just beeps twice when shutting down (the "beep being whatever Windows sound plays when there is an error)
Unfortunately all I can do is confirm that I'm getting the same error message with my new install of C3D 2013 64 bit. I moved up from 2012 C3D, 32 bit. Mostly annoying, but it would be nice to get rid of it. I'll try the repair....
